Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
iPhone 6 Plus Front Panel Assembly Replacement
Абсолютно необходимое руководство
Это руководство предназначено только для использования в качестве обязательного условия для других руководств. Оно не полностью само по себе.
Выберете то, что вам нужно
  1. iPhone 6 Plus Front Panel Assembly Replacement, Front Panel Assembly: шаг 1, изображение 1 из 1
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  2. iPhone 6 Plus Front Panel Assembly Replacement: шаг 2, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  3. iPhone 6 Plus Front Panel Assembly Replacement: шаг 3, изображение 1 из 2 iPhone 6 Plus Front Panel Assembly Replacement: шаг 3, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  4. iPhone 6 Plus Front Panel Assembly Replacement: шаг 4, изображение 1 из 3 iPhone 6 Plus Front Panel Assembly Replacement: шаг 4, изображение 2 из 3 iPhone 6 Plus Front Panel Assembly Replacement: шаг 4, изображение 3 из 3
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  5. iPhone 6 Plus Front Panel Assembly Replacement: шаг 5, изображение 1 из 2 iPhone 6 Plus Front Panel Assembly Replacement: шаг 5, изображение 2 из 2
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  6. iPhone 6 Plus Front Panel Assembly Replacement: шаг 6, изображение 1 из 1
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  7. iPhone 6 Plus Front Panel Assembly Replacement: шаг 7, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
  8. iPhone 6 Plus Front Panel Assembly Replacement: шаг 8, изображение 1 из 1
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  9. iPhone 6 Plus Front Panel Assembly Replacement: шаг 9, изображение 1 из 1
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  10. iPhone 6 Plus Front Panel Assembly Replacement: шаг 10, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
  11. iPhone 6 Plus Front Panel Assembly Replacement: шаг 11, изображение 1 из 2 iPhone 6 Plus Front Panel Assembly Replacement: шаг 11, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  12. iPhone 6 Plus Front Panel Assembly Replacement: шаг 12, изображение 1 из 2 iPhone 6 Plus Front Panel Assembly Replacement: шаг 12, изображение 2 из 2
    • Disconnect the home button cable connector.
  13. iPhone 6 Plus Front Panel Assembly Replacement: шаг 13, изображение 1 из 2 iPhone 6 Plus Front Panel Assembly Replacement: шаг 13, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  14. iPhone 6 Plus Front Panel Assembly Replacement: шаг 14, изображение 1 из 2 iPhone 6 Plus Front Panel Assembly Replacement: шаг 14, изображение 2 из 2
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  15. iPhone 6 Plus Front Panel Assembly Replacement: шаг 15, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
Заключение
19 участников успешно повторили данное руководство.
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 13
За всё время: 8,507
