iPhone 6 Plus Logic Board Replacement
Выберете то, что вам нужно
  1. iPhone 6 Plus Logic Board Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Plus Logic Board Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6 Plus Logic Board Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6 Plus Logic Board Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Plus Logic Board Replacement: шаг 3, изображение 1 из 3 iPhone 6 Plus Logic Board Replacement: шаг 3, изображение 2 из 3 iPhone 6 Plus Logic Board Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Plus Logic Board Replacement, Front Panel Assembly: шаг 4, изображение 1 из 1
    • Use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Plus Logic Board Replacement: шаг 5, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Plus Logic Board Replacement: шаг 6, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 6, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Plus Logic Board Replacement: шаг 7, изображение 1 из 3 iPhone 6 Plus Logic Board Replacement: шаг 7, изображение 2 из 3 iPhone 6 Plus Logic Board Replacement: шаг 7, изображение 3 из 3
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  8. iPhone 6 Plus Logic Board Replacement: шаг 8, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 8, изображение 2 из 2
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Plus Logic Board Replacement: шаг 9, изображение 1 из 1
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  10. iPhone 6 Plus Logic Board Replacement: шаг 10, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Plus Logic Board Replacement: шаг 11, изображение 1 из 1
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Plus Logic Board Replacement: шаг 12, изображение 1 из 1
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  13. iPhone 6 Plus Logic Board Replacement: шаг 13, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Plus Logic Board Replacement: шаг 14, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 14, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  15. iPhone 6 Plus Logic Board Replacement: шаг 15, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 15, изображение 2 из 2
    • Disconnect the home button cable connector.
  16. iPhone 6 Plus Logic Board Replacement: шаг 16, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 16, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Plus Logic Board Replacement: шаг 17, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 17, изображение 2 из 2
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Plus Logic Board Replacement: шаг 18, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Plus Logic Board Replacement, 5GHz Wi-Fi Antenna: шаг 19, изображение 1 из 1
    • Remove the following screws securing the antenna bracket to the rear case:
    • One 1.5 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  20. iPhone 6 Plus Logic Board Replacement: шаг 20, изображение 1 из 1
    • Grasp the 5GHz Wi-Fi antenna bracket with a pair of tweezers and lift it off the iPhone.
  21. iPhone 6 Plus Logic Board Replacement: шаг 21, изображение 1 из 1
    • Carefully pry the 5GHz Wi-Fi antenna connector up off the logic board with a plastic opening tool.
  22. iPhone 6 Plus Logic Board Replacement: шаг 22, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 22, изображение 2 из 2
    • Grasp the 5GHz Wi-Fi antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
  23. iPhone 6 Plus Logic Board Replacement: шаг 23, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 23, изображение 2 из 2
    • The two connectors may be coupled by a single adhesive tab. If this is the case, then they may detach as a pair.
    • Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
  24. iPhone 6 Plus Logic Board Replacement: шаг 24, изображение 1 из 1
    • Remove the following screws securing the 5GHz Wi-Fi antenna to the rear case:
    • Two 1.6 mm Phillips #00 screws
  25. iPhone 6 Plus Logic Board Replacement: шаг 25, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 25, изображение 2 из 2
    • Use a pair of tweezers to grasp and remove the 5GHz Wi-Fi antenna out of the iPhone.
    • During reassembly, make sure to place the small washer in the top left corner of the 5GHz Wi-Fi antenna.
  26. iPhone 6 Plus Logic Board Replacement, Disconnect Charge Port: шаг 26, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement, Disconnect Charge Port: шаг 26, изображение 2 из 2
    • Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
  27. iPhone 6 Plus Logic Board Replacement: шаг 27, изображение 1 из 1
    • Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
  28. iPhone 6 Plus Logic Board Replacement: шаг 28, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 28, изображение 2 из 2
    • Grasp the interconnect antenna cable with a pair of tweezers and carefully de-route it from its channel on the vibrator assembly.
  29. iPhone 6 Plus Logic Board Replacement: шаг 29, изображение 1 из 1
    • Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
  30. iPhone 6 Plus Logic Board Replacement: шаг 30, изображение 1 из 1
    • Remove the vibrator from the iPhone.
  31. iPhone 6 Plus Logic Board Replacement, SIM Card: шаг 31, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement, SIM Card: шаг 31, изображение 2 из 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
  32. iPhone 6 Plus Logic Board Replacement: шаг 32, изображение 1 из 1
    • Remove the SIM Card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  33. iPhone 6 Plus Logic Board Replacement, Rear Facing Camera: шаг 33, изображение 1 из 1
    • Use a pair of tweezers to peel back the piece of tape covering the hidden screw securing the rear-facing camera bracket to the rear case.
  34. iPhone 6 Plus Logic Board Replacement: шаг 34, изображение 1 из 1
    • Remove the following screws securing the rear-facing camera bracket to the rear case:
    • One 1.7 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  35. iPhone 6 Plus Logic Board Replacement: шаг 35, изображение 1 из 1
    • Lift and remove the rear-facing camera bracket off the rear-facing camera.
  36. iPhone 6 Plus Logic Board Replacement: шаг 36, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the logic board.
  37. iPhone 6 Plus Logic Board Replacement: шаг 37, изображение 1 из 1
    • Carefully lift and remove the rear-facing camera out of the iPhone.
  38. iPhone 6 Plus Logic Board Replacement, Logic Board Assembly: шаг 38, изображение 1 из 1
    • Remove the single 2.8 mm Phillips #00 screw securing the plastic clip to the logic board.
  39. iPhone 6 Plus Logic Board Replacement: шаг 39, изображение 1 из 1
    • Remove the single 1.3 mm Phillips #00 screw recessed against the top of the rear case.
  40. iPhone 6 Plus Logic Board Replacement: шаг 40, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 40, изображение 2 из 2
    • Use a pair of tweezers to firmly grasp the plastic clip and remove it from the iPhone.
  41. iPhone 6 Plus Logic Board Replacement: шаг 41, изображение 1 из 1
    • Remove the single 1.6 mm Phillips #00 screw securing the antenna clip to the rear case.
  42. iPhone 6 Plus Logic Board Replacement: шаг 42, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 42, изображение 2 из 2
    • Carefully grasp the antenna clip with a pair of tweezers and remove it from the iPhone.
  43. iPhone 6 Plus Logic Board Replacement, Logic Board: шаг 43, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.4 mm standoff screws
    • Standoff screws are best removed with a standoff screwdriver or standoff driver bit. A small flathead screwdriver can also do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 2.1 mm Phillips #00 screw
  44. iPhone 6 Plus Logic Board Replacement: шаг 44, изображение 1 из 1
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
  45. iPhone 6 Plus Logic Board Replacement: шаг 45, изображение 1 из 1
    • Do not remove the logic board. At this point it is still tethered to the rear case via an antenna connector.
    • Continue carefully lifting the bottom side of the logic board until it is vertical.
  46. iPhone 6 Plus Logic Board Replacement: шаг 46, изображение 1 из 2 iPhone 6 Plus Logic Board Replacement: шаг 46, изображение 2 из 2
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of a spudger to disconnect the antenna connector from its socket on the back of the logic board.
  47. iPhone 6 Plus Logic Board Replacement: шаг 47, изображение 1 из 1
    • Lift and remove the logic board out of the iPhone.
Заключение
186 человек успешно провели ремонт по этому руководству.
Jeff Suovanen
Участник с: 08/06/13
447 009 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 580 руководств
31 Комментарии к руководству
Hello. Good job on these teachings of disassembly. I need help in changing the logic board of my iphone 5 and iphone 6. Where can i buy the logic board? I reside in Nigeria
Kesiah - Ответить
HI do you know who replaces logic boards on iPhone 6?
neffangelica -
I am on Step 29 and the upper-right screw was stripped in manufacturing and I am not able to remove? What is the best way to remove the stripped screw?
Jon Pellant - Ответить
if u can melt a pen and stick it on then twist it if that dosen’t work use a dermel cut the screw and use a flahead
Albert lam -
Is there anyone who has this service Im willing to pay someone who's legit
IBeDECK - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 47
За последние 7 дней: 346
За последние 30 дней: 1,034
За всё время: 270,014
