iRobot Roomba Battery Replacement
Выберете то, что вам нужно
  1. iRobot Roomba Battery Replacement, Loosen the edge brush screw: шаг 1, изображение 1 из 1
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
  2. iRobot Roomba Battery Replacement, Remove the edge brush: шаг 2, изображение 1 из 2 iRobot Roomba Battery Replacement, Remove the edge brush: шаг 2, изображение 2 из 2
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
  3. iRobot Roomba Battery Replacement, Loosen the bottom screws: шаг 3, изображение 1 из 2 iRobot Roomba Battery Replacement, Loosen the bottom screws: шаг 3, изображение 2 из 2
    • Use a Phillips screwdriver to loosen the five captive screws that hold the bottom plate in place.
    • Those screws are captive screws and therefore not removable.
  4. iRobot Roomba Battery Replacement, Remove the bottom plate: шаг 4, изображение 1 из 3 iRobot Roomba Battery Replacement, Remove the bottom plate: шаг 4, изображение 2 из 3 iRobot Roomba Battery Replacement, Remove the bottom plate: шаг 4, изображение 3 из 3
    • Grab the bottom plate with your hand and remove it by lifting it straight up to reveal the battery.
  5. iRobot Roomba Battery Replacement, Unlatch and remove the battery: шаг 5, изображение 1 из 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: шаг 5, изображение 2 из 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: шаг 5, изображение 3 из 3
    • Use your finger to bend the plastic clip and unlatch the battery.
    • Grab the battery with your hand and lift it straight up from inside its recess to remove it.
Заключение
Еще один человек закончил это руководство.
Tobias Isakeit
Участник с: 03/31/14
117 808 Репутация
Автор 188 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 083 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 61
За последние 30 дней: 327
За всё время: 2,937
