Введение
Use this guide to replace a worn-out or dead battery in your Roomba.
If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Make sure your Roomba is turned off and flip it over to access its underside.
Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
Use your fingers to gather all three brush arms and grab them simultaneously.
Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
Use a Phillips screwdriver to loosen the five captive screws that hold the bottom plate in place.
Grab the bottom plate with your hand and remove it by lifting it straight up to reveal the battery.
Use your finger to bend the plastic clip and unlatch the battery.
Grab the battery with your hand and lift it straight up from inside its recess to remove it.
2 человек успешно провели ремонт по этому руководству.
