Моя проблема
Battery is dead.
Мое решение
Successfully replaced the battery with a new one.
Мой совет
Don't be too quick to come to a conclusion of the battery is dead when you realized that the battery is not charging at the MacOS desktop. After I changed the battery with a new one the status remained the same. Which I then realized al the while, it was the charging curcuit of the mainboard failed.
The tell-tale sign that the charging curcuit having issue is when you noticed the Macsafe cable charging light is not turning on.
1 Комментарий
Press F to pay respects.
nietsniE treblA - Ответить Поделиться
