Помощь
Right Joy-Con Teardown
Редактирование шага 6 —
Тип шага:
Перетащите чтобы изменить порядок
Insert the flat side of the spudger or the opening pick between the ZR button and the upper bracket. Lift up on the ZR button until the clips disengage and you can carefully remove it.
There are springs beneath the ZR trigger. Make sure to disengage the clips and remove the button carefully and slowly as the two marked springs will want to fly out
Ваш вклад лицензируется под свободной лицензией Creative Commons .
