The device does not turn on and does not make any noise when power button is switched on and off.
Before turning on your device, make sure it is plugged in. The Black and Decker High Performance Blower has a power cord that needs to be plugged in to work.
If the power cord is damaged in any way, the device may not turn on. Replace the power cord.
If the power button is stuck or nothing happens when you switch it on, replace the power button.
It is possible for the switch to break or accidentally disconnect from the power button. If this happens, disassemble the device and either reconnect or replace the switch.
The powerhead assembly is the orange portion of the device, containing the fan and motor. Replace powerhead assembly if it is damaged.
Disassemble the device to check if the motor is broken. If it is, then replace the motor. Also, if sparks occur when using the device, the motor has most likely been damaged or broken.
The device turns on but there is no air coming out of the blower tube.
If the device has no air coming out of it or you hear a rattling noise within it, open up the cover/clamshell of the device and check if something is stuck in the fan. If the fan is stuck, clean and unclog it.
Disassemble the device and check if the fan is broken or damaged. If it is then replace it with the fan.
The device turns on but there is no suction.
Disassemble the device and check the fan for any visible damage. If there is damage, replace the fan.
The device has little suction or the device sounds like it is struggling.
Open up the housing/cover of the device and check if something is stuck in the fan. If the fan is stuck, clean and unclog it.
The clamshell (black plastic casing) is broken or missing.
If the clamshell is damaged or missing, replace the clamshell. This is important because a damaged clamshell can reveal the inner parts of the device such as the fan and motor. This creates a hazard for the user.
Один комментарий
My B&D blow/vac blows but does not vacuum. Any comments?
Gordon Mathison - Ответить
Просмотр статистики:
За 24 часа: 1
За 7 дней: 10
За 30 дней: 49
За всё время: 1,568
