Radio won't turn on
You've moved the FUNCTION switch to AM or FM and nothing happens.
Drained/bad batteries
It is possible that one or more of the 6 C-cell batteries is either drained, not functioning, or inserted incorrectly and in need of replacement. Learn how to replace them! Alternatively, you could connect the power cord.
A/C Adapter is plugged in but still no power
If the A/C power cord is connected and you are still not receiving power to the radio, the cord itself may be broken, severed and/or the connection port on the radio may be broken internally. If this is the case replacement of the power cord is recommended. Follow our guide to disassemble the radio and check the internal connections.
FUNCTION switch is broken
If both the batteries and the power cord and connection are in good working order, it is possible that the FUNCTION switch itself is broken. In this case, prepare your tools! Partial dis-assembly of the radio will be required to further diagnose its condition.
Buttons are stuck
You press the button and it does not return to its original position.
Buttons are dirty
If your radio is as old as ours, the buttons may have dirt or debris underneath and around them! This is a simple fix. Try cleaning around them first with a small cotton swab and a small sharp tool, like a paper clip! If this does not work, removal of the buttons for a more thorough cleaning may be in order.
Button is broken
It is possible that either the button itself is damaged or internal components such as the spring have become dislodged or broken. In this case, dis-assembly will be required to assess what the issue is and allow for possible replacement.
Cassette is jammed
The cassette is somehow lodged inside the radio.
Cassette EJECT function is malfunctioning
The eject mechanism may be jammed or lodged in the radio housing. Partial dis-assembly may be required to un-jam it! If this does not work, it may be broken and need replacing.
Cassette tape is stuck
If your tape is stuck either in the deck or in the door, try gently prying it out with a small screw driver. If the cassette film is also stuck, the film may be tangled on the turning wheel. Try gently removing it by hand or with a small tool like tweezers.
Volume level or audio quality is poor
Radio is functioning, however you are having trouble getting clear and consistent sound.
VOLUME knob is broken
The radio is working, but when you move the knob towards the 'MIN' or 'MAX' the sound level is not corresponding to the position. The knob itself may be broken or the connection may be broken internally. Find out how to replace the knob here!
Speaker is broken
If the speaker itself is producing sound, but the audio is distorted it may be blown due to overexertion. In this case, needs to be replaced. If there is no sound coming from one or either speaker they may be disconnected internally. In either case, dis-assembly of the radio may be required. You can learn how to replace the speakers here!
Cannot get AM/FM reception
You turn the radio function on and cannot receive clear radio transmission of any station.
Antenna is incorrectly placed
The antenna may be pointed in an unfavorable direction for reception. Try re-positioning it until clear reception is found.
Antenna connection is broken
It is possible that an internal connection for the antenna is faulty. It may be necessary to replace the antenna if the connection is irreparable.
6 Комментариев
i don't know where to turn radio on or off
Barb Rance - Ответить
i do not know where to turn on or off or switch to battery mode There is no on off switch that i can find . The radio works if i plug it in but can not switch it off unless i unplug it.
you have to put the “FUNCTION” button to (TAPE/RADIO OFF)
Tadrees Tadrees -
a me la radio FM funziona, ma non ricevo alcun segnale dall’ AM. Non so ove procedere per individuare qualcosa non nella norma.
FRANCESCO ANTILOPE - Ответить
My radio got rained and it's not functioning where might be the problem
fabyweks - Ответить
