Laptop Repairability Scores
You have the right to repair the things you own—but how easily can that be done?
To find out, our engineers tear down the latest laptops and score their repairability from zero (unrepairable) to ten (easiest to repair) so you can pick a product that is easy to repair and lasts as long as possible.
What makes a repairable device?
It should be straightforward to disassemble and replace whatever’s broken, using parts and instructions supplied (or endorsed) by the manufacturer. But that’s just to start—repairability means so much more. For full details, see our repairability scoring explainer.
Repairability is a moving target
We update our scoring rubric frequently to stay current with new technologies, materials, and design trends. This means that devices scored in years past might not fare exactly the same if they were re-scored today, but they can be readily compared with their contemporaries. For a precise list of criteria used to calculate each score, click the scorecard version number linked to each device below. For a downloadable (CSV) list of all scores, click here.
Laptop Scores
Sorted by newest to oldest
Lenovo Chromebook 14ITN11
2026
PROS
  • Disassembly is straightforward and requires only basic tools.
  • The battery, display, fan, speakers, modular USB-C port, I/O board, and Wi-Fi module are all easy to access.
  • Lenovo provides thorough repair instructions and sells replacement parts.
CONS
  • Storage and memory are soldered, and keyboard repairs require extensive disassembly.
Lenovo Chromebook 14M8911
2026
PROS
  • The battery, display, speakers, modular USB-C port, I/O board, and Wi-Fi module are all easy to access.
CONS
Lenovo ThinkPad P16s Gen 5 (Intel)
2026
PROS
  • Storage and memory are readily repairable/upgradeable using industry-standard parts.
  • Battery, display, keyboard, and fan replacements are straightforward and well-prioritized.
  • Overall very high modularity, although some ports remain soldered to the system board.
  • Lenovo offers thorough repair instructions and replacement parts.
Lenovo ThinkPad T14 Gen 7 and T16 Gen 5
2026
PROS
  • The battery is easily replaced, and the keyboard replacement procedure is best-in-class.
  • Overall very high modularity, including individually replaceable Thunderbolt ports.
MacBook Pro 14-inch (M5, 2025)
2025
PROS
  • Battery replacements are do-able (if not exactly easy).
  • The Thunderbolt port design is highly modular and repair-friendly.
  • Apple offers a full service manual and a good selection of replacement parts for end users.
CONS
  • Storage is not removable or serviceable, the keyboard is riveted down, and pentalobe screws bar the way for all repairs.
Lenovo ThinkPad P16 Gen 3
2025
PROS
  • Lenovo typically provides thorough support for P-series repairs (instructions and replacement parts).
CONS
  • All ports are soldered to the system board, and the fan is permanently affixed to the heat sink.
Lenovo ThinkPad L16 Gen 2
2025
PROS
  • Overall very high modularity, apart from most I/O ports being soldered to the system board.
Lenovo ThinkPad 13w 2-in-1 Gen 3
2025
PROS
  • Battery, display, and fan procedures are prioritized and generally straightforward.
  • Overall very high modularity, apart from soldered ports and the keyboard/top case assembly.
Framework Laptop 12
2025
PROS
  • Highly modular design makes nearly all common repairs very easy.
  • Storage and memory can be repaired/upgraded with industry standard parts.
  • Friendly labels and QR codes adorn the internal components so you’ll never get lost.
  • Framework offers thorough repair instructions and replacement parts.
Lenovo ThinkPad L14 Gen 6
2025
PROS
  • Overall very high modularity, apart from the I/O ports being soldered to the system board.
Lenovo ThinkPad E14 Gen 7
2025
PROS
  • Overall high modularity, apart from soldered ports and the keyboard/top case assembly.
Lenovo ThinkPad E16 Gen 3
2025
PROS
Lenovo ThinkPad T14 Gen 6
2025
PROS
  • Overall high modularity, apart from a handful of soldered ports and a bundled fan/heat sink assembly.
Lenovo ThinkPad T16 Gen 4
2025
PROS
MacBook Air 13″ (M4)
2025
PROS
  • Battery repairs are tough but do-able, and the fanless design is low-maintenance.
  • Apple has already published their service manual, and replacement parts will likely be available soon.
CONS
  • Storage is soldered, the keyboard is riveted down, and software calibration issues hinder some repairs.
Lenovo ThinkPad E16 Gen 2
2024
PROS
  • Lenovo provides impressive E-series repair support, including support documentation and spare parts availability.
Lenovo ThinkPad E14 Gen 6
2024
PROS
Microsoft Surface Laptop 7
2024
PROS
  • Entry and access to main components is uncomplicated.
  • Microsoft provides a thorough set of repair manuals, sells spare parts, and makes their SDT software publicly available for post-repair calibrations.
CONS
  • Troublesome board shields interfere with display replacements.
  • The keyboard is riveted to the chassis.
Lenovo ThinkPad L14 Gen 5
2024
PROS
  • The storage, memory, display, fan, and battery are prioritized, making for simple repairs.
  • The keyboard replacement procedure is best-in-class.
  • Impressive modularity, apart from a handful of soldered ports.
Lenovo ThinkPad T16 Gen 3
2024
PROS
Lenovo ThinkPad T14 Gen 5
2024
PROS
Framework Laptop 16
2023
PROS
  • Repairability is strongly prioritized in the design from top to bottom.
  • Virtually all major components are modular and readily replaceable, including the graphics module.
  • Framework typically offers a factory service manual and a robust selection of replacement parts for end users.
MacBook Air 15″ (M2)
2023
PROS
  • Apple offers full repair instructions and replacement parts for end users.
CONS
  • Storage is soldered, the keyboard is riveted down, and pentalobe screws bar the way for all repairs.
MacBook Air 13″ (M2)
2022
PROS
CONS
Lenovo ThinkPad T14 Gen 3
2022
PROS
  • Most repairs are very straightforward and require only basic tools.
CONS
  • Partially soldered memory and I/O ports hinder certain repairs.
MacBook Pro 14″ (M1)
2021
PROS
  • Battery replacements are well-prioritized, if not exactly easy.
CONS
