Руководства по ремонту и разборке проекторов.
Projector won't switch on
The projector doesn't switch on. Had the power supply replaced a few months ago to solve this problem and it worked for a bit after that but it's given up again. Can anyone advise or provide a service manual?
Это хороший вопрос?
Счет 2
2 Комментариев
hello can you tell where i can find a power supply for my plc xp 57 which is the model above yours ,i think the same power supply will work ,i look all over the net and i can't find it,thanks in advance
из Поделиться
epson eb-s03 projector have power suppy but can't turn on. when I plug power have a blue coler in button but can't turn on it
из Поделиться
Добавить комментарий
3 Ответов
Выбранное решение
David Hicks, I'd definitely check the power supply first. Of course, start with the fuse F601 and R661 on the logic board. BTW,here you go :-)
Был ли этот ответ полезен?
Счет 3
5 Комментариев:
Thank you. The manual shows where the components are on the circuit board but refers to the main service manual which, I assume, will show how to take things apart to get at the board! Can you provide that one too?
из Поделиться
found the main service manual at http://diagramas.diagramasde.com/otros/P.... Typical: the power supply board is at the bottom and requires almost complete disassembly...
из Поделиться
Of course, you did not expect anything easy and user friendly :-) BTW good find, I will delete my link ;-)
из Поделиться
i guess not. since it's broken and the supplier's advice is to cut my losses and replace I've got nothing to lose by taking it apart... more in hope than expectation. Thank you for your help. oldturkey03.
из Поделиться
That is where places like this one, ifixit, does come in handy. If we would listen to the resellers and suppliers, we would be throwing stuff out, just to turn around and spend some more money on new ones. I bet the repair for your projector will only cost a fraction of what a new one would be....best of luck to you and let us know how it is working out.
из Поделиться
i think the power ic..replace the power ic and then change the new power ic..
Счет 0
Check the connector between the lamp and the ballast for oxidation on the contacts
especially the end of the ballast cord with the connector the lamp plugs into and clean with abrasives.
Счет 0
Добавьте свой ответ
David Hicks буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 52
За все время: 38,091
