Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2376вопросов Показать все
Device does not power on
I have an IPhone 4 that does not power up or does an over night charge seem to help. It will not connect to ITunes or will my computer seem to acknowledge it's even connected. Could it be the battery or something else?
Это хороший вопрос?
Оценка -1
1 Комментарий
I will keep you informed on the status. Thank you for some additional directions if the battery does not resolve the issue.
из
Добавить комментарий
1 ответ
Выбранное решение
scassidy, yes, it could be the battery. But it is also possible that it is the dock connector. The dock connector is the part that would tie together the charging and the connection to your computer. I'd start with the battery, and then the dock connector. Use this guide to replace the battery, and this one for the dock connector. You also should try a different cable, just to make sure that that is not was cause you the trouble. Hope this helps, good luck.
iPhone 4 Аккумулятор Изображение
Инструкция
Замена аккумулятора iPhone 4
Сложность:
Модерировать
iPhone 4 Dock Connector Изображение
Инструкция
iPhone 4 Dock Connector Replacement
Сложность:
Сложно
45 minutes - 1 hour
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
oldturkey03, thank you for your response. I ordered the replacement battery along with a tool kit. I hope the battery resolves the issue. But with the dock connector, I tried 3 cables and still no resolve. Could it be the dock connector instead of the battery since I tried 3 cables?
из
scassidy, yes it could easily be the dock connector. You are doing the right thing by starting with the battery, if nothing else it will give you a clean starting point. If that does not work, try a new dock connector. Thank you for accepting my answer.
из
Добавьте свой ответ
scassidy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 190
