Replace A1286 Mid 2009 Logic board with a mid 2010 one?
I've looked deep into this over the course of the past 2 months, and I've came to the conclusion that all of the connectors and components between the Mid 2009 C2D logic board and the Mid 2010 Core i7-620m logic boards are identical, except for the heat sink, bluetooth and wifi board, and isight/antenna cables. All of the screw holes line up (they are both a1286 model number) and both use a nvidia chipset, so it seems the screen would work correctly without any modifications or additional parts.
I'm just wondering, what would the killer be when buying a mid 2010 logic board (with a core i7), a new isight/antenna cable, and a new bluetooth/wifi board and upgrading my computer this way rather than buying a newer macbook pro.
Это хороший вопрос?
Счет 0
2 Комментариев
Hey did the upgrade work for you? Im thinking along the same lines when it comes to my macbook...
из
Добавить комментарий
2 Ответов
Выбранное решение
The top case is a bit different as well. The are screw holes for the subwoofer on the 2010 which the earlier model lacks, and the bluetooth antennae on the 2010 has a piece of metal that looks like it attaches to the frame (glued?). The older model has a thin black plastic material covering that area (which appears to be cut away on the newer one, but I couldn't find any info on removing it and didn't want to mess it up so I left it in place.
HTH someone.
Был ли этот ответ полезен?
Счет 1
If the model number is the same, it should work. However, I would recommend getting a brand new one as it will be much better.
Счет 0
1 Комментарий:
Apple uses the same model numbers for very different systems. They cannot be used to determine compatibility except very generally.
из
Добавьте свой ответ
Mason Bleily буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 2,019
