4-гигабайтный MP3-плеер Sylvania с 3,6-дюймовым сенсорным экраном для воспроизведения видео.
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Выбранное решение
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
What does a battery cost and where can one be bought?
из
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
из
It was not working and how to fix it.
Счет 0
1 Комментарий:
Um... what are you talking about???
из
My sony walkman wont turn on
Счет 0
Добавьте свой ответ
henryr79 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 20
За все время: 3,026
