Tickle Me Elmo — это детская игрушка от компании Tyco-Preschool, основанная на персонаже Элмо из детского телешоу «Улица Сезам». Она была представлена в США в 1996 году.
New batteries, doesn't work.
He was working. Changed the batteries and now he doesn't. Am I missing something here? Is there anything I can try?
Это хороший вопрос?
Счет 3
8 Комментариев
When was the last time Elmo worked? You checked the batteries, the proper position and checked for corrosion on the battery contacts?
из Поделиться
I fond a plastic bag in the foot of mine why is it there
из Поделиться
I have a 20 year old Elmo the shaker box stopped working, how do I get a new one.
из Поделиться
hey there do you still have the shaker box?
из Поделиться
Mine also does not work after replacing batteries....plz tell me where to get another shaker box
из Поделиться
Показать ещё 3 комментариев
Добавить комментарий
3 Ответов
Выбранное решение
Did you replace ALL the batteries?
Instructions
Open the door to the battery compartments on the bottom of Elmo's feet with a Phillips head screwdriver. Remove the old batteries.
2
Place the AA batteries in the battery compartments according to the polarity indicators designated by a (+) and (-) sign.
3
Replace the battery compartment covers. Replace the screws. Set the "On/off" switch on the bottom of Elmo's right foot to "On."
4
Slide the back cover off the activation box. Install the two AAA batteries in the compartment. Place the batteries in the compartment according to the polarity indicators inside the case.
Был ли этот ответ полезен?
Счет 2
8 Комментариев:
do I mash anything to make it start after batteries
из Поделиться
Where is "the back cover off the activation box"? and how do I access it?
Thank you.
Mike D
из Поделиться
Mike, it's on the back. See the diagram here: Where is Location of Elmo's Activation Box Cover?
из Поделиться
I replaced the battery, not working.
из Поделиться
Mine was working fine put in box.....when I took it out put new batteries just wont turn on....tried everything??
из Поделиться
I put new batteries the bottom of the feet and still will not work
Счет 1
I can not get my tickel me Elmo to work after installing new batteries.
Счет 0
Добавьте свой ответ
Jean буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 26
За последние 30 дней: 81
За все время: 16,946
