Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
iPhone turning off while doing something.
Hi,
i have an iphone 3gs. The problem is, that- it is turning off even it has 50% charge. Its happening when im doing something on it, like playing a game. I have replaced a battery two times. Nothing has changed. Do you maybe have any ideas what can it be? Maybe I need to replace something else, and it is not the battery fault?
Sorry for my english, it's not my first language.
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
Daniel, since you already replaced the battery, and I suppose it is the right APN number (remember that there was some issues with the 3GS batteries), then my next step would be the dock connector, inspect it for any broken, bend or corroded pins, replace it if necessary. If that does not resolve the issue, you may have trouble with the PMIC on the logic board. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thank you for your answer. I checked the battery APN and its 616-0435. So it seems to be right. However I took the very oryginal battery from another iphone 3gs. So now its working, I will see what will happen next.
из
Definitely sounds like a battery issue. I would replace the battery.
из
Добавьте свой ответ
Daniel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 136
