Модель A1278 середины 2010 года / процессор Core 2 Duo 2,4 или 2,66 ГГц
Nvidia 320m reflow profile?
I have a Macbook pro 13" mid 2010 that I believe to have a faulty connection between the GPU and the logic board due to over heating.
I'm wondering if anyone that has re-flowed one of these could give me an idea of the temps required to fully melt the solder. I am not even sure if they use lead free or lead solder on these Macbooks.
Это хороший вопрос?
Счет 5
2 Комментариев
Hey! What happened with your mac?
из
Hi Steven,
I am wondering, how did the reflow go?
Because I have the same symptoms with a macbook white 2010
Did you do anything else to fix this problem?
thanks for share your knowledge
из
Добавить комментарий
1 ответ
Выбранное решение
Steven, right now my concern would be that you need to know that it is not necessary to "to fully melt the solder" for a reflow. I suggest that you get an old board first and practice a reflow. I assume you are going to use a hot air gun. There is a lot more to a reflow than blasting some hot air onto the processor. You could also tell us why you "believe to have a faulty connection between the GPU and the logic board due to over heating." Yes, it is lead free solder. Here are some basic temps that you will need to know "The lead-free alloy used for BGA solder balls has a melting point of 217°C. This alloy requires a minimum reflow temperature of 235°C to ensure good wetting. The
maximum reflow temperature is in the 245°C to 260°C range.
When using a reflow station, for a processor like your NVidia, the profile looks usually like this :
Profile Feature
Average ramp-up rate (Tsmax to TP)
3°C/ second maximum
Minimum preheat temperature (Ts MIN)
150°C
Maximum preheat temperature (Ts MAX)
200°C
Preheat time (Ts MIN to TsMAX)
60–120 seconds
Temperature (TL)
217°C
Time above liquidous temperature TL
60–150 seconds
Peak temperature (TP)
260°C
Time within 5°C of peak TP
30sec
Average ramp-down rate (TP to TsMAX)
6°C/ second maximum
Time 25°C to TP
8-minutes maximum
All temperatures refer to the topside of the processor, measured on the processor body surface. Of course this is for a reflow station based on a lead free BGA IC. Best places to check out first, would be the Xbox360 and PS3 forums. After all, those are the birth places for the home reflows. I attached an image which also shows a common reflow profile. Check this video for a GPU reflow, different computer, same idea. Hope this helps, good luck
Был ли этот ответ полезен?
Счет 6
8 Комментариев:
Hi, thanks so much for the detailed response.
Some of the symptoms that lead me to believe I believe to have a faulty connection between the GPU and the logic board.
-Upon pressing the power button the unit powers on ( fan spins, white led illuminates )
- No chime
- Screen does not come on or light up in anyway ( apple logo on lid does not illuminate )
- Keyboard shows no sign of life ( caps lock does not come on and keys do not illuminate )
- USB ports do not seem to function ( plugged a USB light in during startup )
Seeing the GPU chip has the Southbridge onboard which controls sound, keyboard, USB along with the screen not showing any signs of life my guess is that the GPU over heated and may need to be reflowed.
I've tried
- resetting smc and pram
- resetting all cables and connections
- reseating all hardware
I have some experience in reflowing laptops, desktops and video cards with a hot air station and just recently acquired a PCB preheater. I am just now starting to work on Macbooks so this will be my first attempt at a GPU re-flow on a MBP. There for I would like to gather as much information as possible before jumping .You can see some of my reflow videos here http://www.youtube.com/user/CPRcomputers...
из
That is great, good videos as well. I think that it is more important to know how to do a reflow, than knowing about the individual boards. As you know, the importance is the individual IC, not the board that it is on. Let us know how you made out with it, may be you can create a guide so we can all see how it is done properly. Best of luck to you.
из
I'm not used to using a pre-heater so I just want to be sure I have this correct. Looking at the above profile it looks like this whole preheat and re-flow should take no longer than 4-5 minutes?
Is this correct?
1) Preheat to 200C within 120 seconds ( 3c per second )
2) Raise and steady to 217C for 60-150 seconds
3) Raise to 255C-260C for 30 seconds
4) Cool off ( 6C per second ) to at least 70c
all temps measured topside.
из
That looks about right...:-)
из
Thanks oldturkey. I'm taking some practice runs with a couple old motherboards with NVidia chips to get use to the preheater. Its a good thing too because I didn't realize that this preheater runs in 6 segments. I thought the segments were profiles so I only set up the first segment and couldn't figure out why it didn't start the cool down process after the programed time. :/ oh well, now I know. Wish me luck!
из
Показать ещё 3 комментариев
Добавьте свой ответ
Steven буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 23
За всё время: 29,776
