Repair and disassembly guides for a large selection of Canon digital and film cameras.
1797вопросов Показать все
Service Manuals for Canon Powershot cameras?
Does anyone have a source for Service Manuals for Canon Powershot cameras? I have many working Powershot models but there is dust INSIDE the lens/ccd and I would love to take it apart to clean it. I need service guides or take-apart instructions for Powershot S100, S110, S200, SD400, SD600, SD780, SD940, SD1000, SD1100, and SD1200.
Это хороший вопрос?
Оценка 4
1 Комментарий
If you do get them all apart, I would encourage you to document the process. http://www.ifixit.com/Guide/new
из
Добавить комментарий
7 Ответов
Выбранное решение
I think many people have their sources - but i see there a slightly legality issue - so the only answer i would give is: "google it"
Был ли этот ответ полезен?
Оценка 3
Наиболее полезный ответ
I don't have a service manual for you, however I've taken apart my Powershot S500 several times, including opening the lens/sensor assembly to successfully clean dust on the sensor.
I documented it in this teardown report here on ifixit. From other Powershot cameras I have seen and poked around with, the construction of others is very similar so even if you're wanting to do this with a different model, you may find my photos instructive.
I also notice there are some additional repair guides for other Canon models here on ifixit now - take a look at those also.
if you are handy with taking apart things and handling tiny screws and delicate ribbon cables, you may be able to take apart your camera without a service manual. basically just take it apart one screw at a time, save and label where the screws go, and perhaps take photos along the way (that's how my teardown photos came about). then reverse the process when done. good luck!
Оценка 4
Here's a link to the repair manuals for the Canon Powershot - Pro1, S10, S45, A70, A95, IXUS II/SD100, it's not everything you want but should give you a very good idea of how they work: http://qman.fotokala.ee/
Оценка 2
7 Комментариев:
This link is dead - the domain is for sale.
из
@johncc Jon the question is 9 years old.
из
Hi, Mayer. Not criticizing you! Just trying to save time (and hope) for someone else. I'm still looking for a guide for the SX170...
из
Mayer, I already received more than 75 identical notices of your original comment by mail. What's happening?
из
@johncc Looks like a glitch in the iFixit mail system. I will notify them to stop it, may take till Monday.
https://meta.ifixit.com/Answers/View/139...
из
Показать 2 больше комментариев
Google the following: "POWER SHOT S400 - IXUS 400.pdf" (without the quotes). You will find the parts list that gives you an idea on how to dismantle it.
I found the document here: http://www.micro-tools.net/pdf/Canon/POW...
jflarin
Оценка 0
Try to find here http://service.gex-bbs.ru/canon_camera.
Оценка 0
1 Комментарий:
Gives a 404 error
из
Our Canon Camera repair manual section is growing constantly. We have quite a few PowerShot models already, and we get more every few months.
Оценка 0
Look service manuals here: http://www.smpcshop.com/Canon-Cameras-Se...
Оценка 0
Добавьте свой ответ
Rei Yoshioka будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 10
За последние 30 дней: 25
За всё время: 25,289
