The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
115вопросов Показать все
My motor does not have screws but are smooth flat head
my motor does not have screws but are smooth flat head
Это хороший вопрос?
Оценка 0
4 Комментариев
Alan Hobart, what motor, what screws, what flat head??? What are you trying to do and what are you asking?
из
Alan, please do elaborate. There is not enough information here for us to be helpful. Thank you!
из
Okay, let me guess. Motor? Window motor? Flat head...??? Um maybe the screws/rivets that hold the window motor to the window regulator? That's the only thing I can think of based on your incomplete description. Give us more detail.
из
I think you're on to something there Isoldano. I'll follow up with an answer I think will help...
из
Добавить комментарий
1 ответ
Выбранное решение
Best guess based on the comments above is that you mean that your window regulator motor for one of the power windows on your W123 chassis Mercedes does not have a back cover that screws open as described in this guide:
Guide on maintaining "Screw Open" style window motors
So what you'll want to do is take a look at the guide for the other style, which can be easily drilled open and modified to then use screws for easier future maintenance:
Guide on maintaining "Drill Open" style window motors
Mercedes W123 Изображение
Инструкция
How to fix Mercedes W123 "screw open" style window regulator
Сложность:
Легко
10 minutes
Инструкция
Repairing Mercedes W123 Window Regulator "Drill Open" Style Window Motor
Сложность:
Модерировать
30 - 45 minutes
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Alan Hobart будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 338
