just doesn't pump water out
my GE washer/dryer stacked combo model # WSM2700HAWWW ... the washer runs, spins fills with water, washes , just doesn't pump water out... is the pump the problem?
Это хороший вопрос?
Это хороший вопрос?
Hi
If it ran, spun and then filled with water again it is not the pump. It worked after the first spin.
Был ли этот ответ полезен?
In my experience, Most of the time a sock or something small will slip past the inner tub and into the pump
what i'd do is use a Zip-tie to block the waterflow from the full tub, remove the clamps, hoses off the pump. look inside and pull whatever it is out. if the impeller is visibly busted its time for a new pump
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 27
За всё время: 951
