Kenmore Elite HE3 — это электрическая сушильная машина от Kenmore с объемом барабана около 204 л.
Dryer won't start Error Code F70
Just had a Thunderstorm and lightning hit very close to our house blew 2 circuit breakers. I reset them and everything came on in the affected rooms. When my wife tried to start the dryer it wouldn't start and has an error code of F70 flashing. What does this mean and wan I fix it or do I need a technician?
Это хороший вопрос?
Счет 6
Добавить комментарий
1 ответ
Выбранное решение
Doug, F70 means check harness connections at the machine control and at the console electronics. If your connections are fine to the machine control board and the console electronics, then you may need to change the machine control board. Unplug your dryer first and leave it unplugged for a while to see if it resets It is below the top panel on the left hand side of the dryer panel. I attached the tech sheet for the dryer to the bottom of this page. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 6
3 Комментариев:
I replaced a circuit board run as described "https://www.youtube.com/watch?v=eWqrn5kl...: However, I did not properly seat one of the plugs. I reopened dryerthe board and checked the plugs. Once I found the loose plug, I re-seated it properly and the dryer came up perfectly.
Thank you so much for this excellent video.
из Поделиться
Thanks to this information above I was able to get mine going too!!!! (Thank you)
из Поделиться
coding F01 is iqual a F70?
из Поделиться
Добавьте свой ответ
Doug буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 17
За последние 30 дней: 44
За все время: 36,038
