Первое устройство Nokia нового поколения: первое с экраном 1080p и первое с четырехъядерным процессором Krait
it's it possible to replace the front facing camera
it's it possible to replace the front facing camera?
Это хороший вопрос?
Счет 3
1 Комментарий
I had the same question. The cable became damaged during a screen replacement and I found the replacement camera. Just not sure if its glued on or soldered or some other method. Any tips would be appreciated.
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Use can use these videos.Its really help me a lot for changing my camera.
https://www.youtube.com/watch?v=HQC2lZsB...
https://www.youtube.com/watch?v=qmNUl9Gh...
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Neither video is for a 1520. one is for a rear camera and one is for disassembling the 900. Unfortunately neither have a similar front facing camera to the 1520. Did you replace the front camera on a 1520? Thanks for any help you can provide.
из
Use 3m z conductive double sided band. 3M 9703
https://www.tedpella.com/TechNote_html/1...
Счет 1
3 Комментариев:
Also do not forget to heat 70 degrees C. otherwise it will not work.
из
Thank you!
But with this method. all the circuits of the camera you do not risk it to get in touch with each other?
из
The tape is conductive only for Z direction(vertically). Side by side contacts will not be connected. I did it and worked.
из
Yeah, it's possible. Open the phone, find the broken front camera and replace it. But you must have bought the front camera replacement in advance.
Счет 0
3 Комментариев:
Do you have a guide our video that could show me how before I buy the part?
из
is there a guide or instructions. I can't tell if the front camera is glued down or soldered to the mainboard.
из
I have the same problem I have my camera replacement but not how to do it
из
Hello,
I raise the subject, someone found a solution to replace the front camera?
Счет 0
Добавьте свой ответ
bob буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 2,391
