2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265вопросов Показать все
Вопрос закрыт
What screwdriver do I need for 2.3 and 3.0 mm pentalobe screws?
What is the pentalobe screwdrivers size? Such as P4, P5. For the lower case of late 2012 MacBook retina.
I don't see anywhere stated there needs to be 2 kinds of drivers, and where are the specific screws located on the panel? Please put diagram for different sized screws on the same panel
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You'll need a P5 Pentalobe screwdriver and look here at Step 1 - MacBook Pro 13" Retina Display Late 2012 Lower Case Replacement for the different screws locations.
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
If this answer answered your question please remember to rate (score) and mark it accepted.
из
the p5 pentalobe works on both size 2.3 and 3.0 screws on the lower body?
из
Yes, the bottom cover case screws are the same head, some are just longer.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 3,396
