Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Audio Jack Connecting Socket
Hi, I was too rough pulling the audio jack flexi ribbon out of the socket and need to replace the connector on the motherboard but cant seem to find how many pins the connector has anywhere! Are you able to help? Any ideas where to find the info I need please reply :)
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Hi Kayleb,
The part you are looking for (FPC connector J5501) has 37 pins. This connector is also used on the same logic board for attaching the front panel (i.e. the two identical connectors at the bottom of the logic board). You can order it here.
However, see this earlier post here on ifixit.
Steffen
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Kayleb буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 236
