Toshiba Satellite L300 — это ноутбук, разработанный и выпущенный компанией Toshiba, который поставлялся с одной из версий Windows Vista. Устройства продавались примерно в мае-июне 2009 года. Хотя они не подпадали под программу бесплатного обновления до Windows 7, а сроки давно прошли и обновления более недоступны, ноутбук хорошо работает под управлением Windows 7 Home Premium без обновлений, в основном из-за высоких системных требований Vista. Также известен как Toshiba Satellite L300-04P (PSLB8C-04P01X).
Power supply won't connect
Hi
The post inside my laptop that the power cord goes onto doesn't seem to make a connection anymore. If you put something in there you can see that the post moves around pretty freely so it must have either broken or come loose. Is there a way for me to fix this or do I need to find a repair centre?
Thanks!!
Это хороший вопрос?
Счет 3
1 Комментарий
I have the qosmio x75 and it stopped all together, no charge light, no light, and no screen, any suggestions on what to do to fix. Please
из
Добавить комментарий
5 Ответов
Выбранное решение
Hi, This seems to be a common problem with the Toshiba. Here is a link to a successful mod to repair the problem. Please pay special attention to the cautions the modder makes and read all the way through before deciding to do this. Good luck. Ralph
http://www.insidemylaptop.com/repair-dam...
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
+ for doing the work others didn't
из
After you take apart the laptop, if it is just a loose connector, you should be able to just solder it back in place.
Счет 0
I have this happening to my Toshiba again - third time since I began using it in December 09. Going to try the workaround to see if I can avoid buying yet ANOTHER power supply. Thanks!
Счет 0
It says something like my adapter broke
Счет 0
Using Toshiba Satellite Radius 14 and worst laptop ever. Power cord doesn't keep connection after 1 year and on their website they want $55! The screen broke on one side at 7 months when your supposed to be able to make a tablet, never again.
Счет 0
Добавьте свой ответ
nicksmom1962 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 20
За всё время: 32,337
