7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
LCD - Backlight missing some illumination
Just replaced the digitizer and on re-assembly I've noticed the bottom edge of my ipad has four dark patches. Looks like some of the backlighting LED's are not working? Could it be a single damaged filter connecting the LCD connector? Looks like there are 6 LED drive connections off the connector, so just wondering if I have blown a filter?
Cheers,
Matt
Это хороший вопрос?
Счет -1
5 Комментариев:
Matt, Can you post a picture.
из
Any ideas guys??
из
help?? Please..
из
Hey Matt--looks like you solved this, congratulations! You want to update this question to show us which component was damaged?
из
Добавить комментарий
1 ответ
I guess the only way to really know is too try a different LCD. The LCDs are pretty fragile. Could also be connector damage, but try a different LCD first then go from there.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
It was the filter - one of the 6 was o/c, therefore losing a string of Led's.
из
http://www.cyberdocllc.com/wp-content/up... Replaced one of the 6 filters (labelled as Resistors) as shown on this photo in the green box. These 6 Filters connect to the LED Strings in the LCD, so if one goes down you lose a whole string! :-)
из
Добавьте свой ответ
matt74 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 177
