Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Replaced inverter, now makes noises.
MacBook 2008 OS 10.6.8
The backlight started to fail randomly so I took my MacBook to a repair shop and they replaced the inverter. The backlight works fine now.
The problem now is:
Whenever the backlight is not at minimum or maximum, the inverter makes a noise, like a whistle.
They have tried different inverters, which still did the same noise. They told me replacing the screen will solve the problem, but that costs 100€ and I don't won't to invest this money on such an old laptop.
The noise responds to the level of light in the screen. The pitch gets higher and lower depending on the backlight. Also, for some positions of the screen the noise gets louder.
My question is:
Why does this happen? Is it that the inverters they are trying are cheap ones? Is it maybe that I have to replace the inverter cable too?
Thank you, and excuse my English.
Это хороший вопрос?
Оценка -1
2 Комментариев
It wont be the cable. Sounds like the inverter is making noise possibly from the transformer due to the filter capacitors.
из
Where did you buy this inverter?
из
Добавить комментарий
Ответов (2)
Выбранное решение
@Tim - Here's the location of the inverter and how to get to it: MacBook Core 2 Duo Inverter Replacement as to finding the part heres the part: MacBook Display Inverter
Replace a broken or damaged display inverter for your MacBook with this part and fix backlight issues. This part is compatible with all 13.3" MacBooks (excluding MacBook Unibody and MacBook Air). Изображение
Продукт
$14.99
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thanks for your answers. I bought the inverter at the IFIXIT Store. It's very expensive to send the inverter back to IFIXIT. So I've decided to buy a second hand MacBook and my problem is solved.
из
Try this!
Продукт
$14.99
Оценка 0
Добавьте свой ответ
Miquel будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 147
