Mac Mini 2014 won't boot after installing SSD
After following the guide and replacing the 1TB drive that came in my Late 2014 Mac Mini, my Mini will not boot up. There are no sounds, no fan. I've double checked all connections several times.
The only concern I have, is there is a contact tab of some sort on the hard drive assembly that may have been bent slightly during the process. It looks as though it should either be contacting the outside case, or NOT contacting the mini case itself as some sort of ground, or shock resistance? I'm not sure, just very frustrated at this point.
Это хороший вопрос?
Счет 1
Добавить комментарий
