Sony Xperia Z3 Compact выпущен в сентябре 2014.
82вопросов Показать все
I replaced the LCD Digitizer and now the lcd is blank
Hello, I replaced the LCD Digitizer of a sony xperia z3 compact and now the LCD is not working. The phone powers on fine. The light flashes and the screen vibrates when I touch it.
Это хороший вопрос?
Оценка 1
1 Комментарий:
Hey, I am having same problem. Did you get to resolve issue??
из
Добавить комментарий
5 Ответов
Hey Liam, did you try to redo the assembly of your device. It could be a possible that the LCD may be faulty but redoing the installation could confirm this.
-Let me know how it goes.
Был ли этот ответ полезен?
Оценка 0
Same problem, any solutions?
Оценка 0
Same problem here :( Anyone know how to fix this?
Оценка 0
Same problem, but I see "color snow" when turn on
Update (02/04/2016)
What is it?
Оценка 0
2 Комментариев:
[image|750231]
What is it?
из
I see it, when phone turning on
из
like iapple said redo installation. it is remotely possible that something was hooked up wrong like backwards or something. also it is possible that the figitizer you have is not really made for the phone. I doubt that one but youhave to explore all of your options. The digitizer could also be faulty like Iapple stated earlier. but yeah firstly just make sure that the connections are correct and then go from there
Оценка 0
Добавьте свой ответ
Liam Hannigan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 8
За всё время: 897
