Модель A1502 / двухъядерный процессор Intel Core i7 с тактовой частотой 2,6 ГГц (Turbo Boost до 3,1 ГГц) или 2,8 ГГц (Turbo Boost до 3,3 ГГц) и 4 МБ общей кэш-памяти L3.
I have no video; backlight comes on but display is black
Retina MacBook 13" suddenly has no video; apple lights up, so the backlight is working, but screen is black. Plugging in external monitor via DisplayPort shows "No Signal" on the external monitor.
Am able to ssh from another computer, but
"system_profiler SPDisplaysDataType |grep Resolution"
doesn't do anything (works fine on other computer)
Is there a video card that could have gotten dislodged somehow? Any other ideas what it might be and how to fix it?
Это хороший вопрос?
Счет 3
1 Комментарий:
Aron, how did you solve your problem? I have just the same!
из
Добавить комментарий
2 Ответов
Flash BIOS on new chip, and make sure it has a clean ME region or it will work like junk.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Is there a procedure for doing this? I just installed a new screen and get the same result. My external monitor still works but I can't get the newly installed retina display to work.
из
The video card is soldered onto the board on the MBP Retina. It can't become dislodged, but it can break. I have a user with this issue on a Mid 2014 15" which is why I'm here. He can get video on an external monitor. Apple will repair for a flat rate mail in, don't let them charge you full price for the part - only do a depot repair.
Счет 0
2 Комментариев:
I have exactly the same problem. The video card is broken. What is a depot repair ? My Apple Store charge me the full screen !
из
If they replace the screen it won’t repair the issue if it is the video card. It is the motherboard. Ask for a depot repair, they know what it is.
из
Добавьте свой ответ
Aron буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 1,270
