Руководства по ремонту проводных наушников Beats Studio 2.0. Впервые выпущены в 2013 году. Номер модели: BT OV STU BLK.
Won't even turn on
My beats won't even turn on. Won't charge, nothing. Went to a repairer who said Apple will send a refurb pair if I pay $275. Is there a cheaper way to fix them?
Это хороший вопрос?
Счет 52
65 Комментариев
My beats solo 2.0 wireless will charge but won't turn on. I tried resetting it and it didn't work. The lights were flashing but nothin worked. PLEASE HELP
из
And it only works with a wired connection
из
It wont work if i reset it and it will turn red and white three times but after that it doesn't turn on and its like i have to keep resting and resting but is still don't work and i tried putting it on the charger for like 10 minutes and 1 hour but it still doesn't works so can you please help me please . And i'f also asking if i can listen to music on Bluetooth while its on the charger . And please please help
из
I have beats solo 2 wireless and I have been trying to reset them for so many times. The lights blink 3 times but nothing still happens...somebody please help!!
из
Same problem as Teyon.
из
Показать ещё 60 комментариев
Добавить комментарий
35 Ответов
Выбранное решение
I found a solution to this problem you just hold down the power button and the mute button for 2mins, make sure you press both of them down and make sure you press them down for 2mins no less than that. Then the leds should flash and the headphones should work.
Был ли этот ответ полезен?
Счет 72
113 Комментариев:
Ok i'm going to try that . And thanks so much if this works .
из
thanks i tried this and it worked.
из
By "mute button" are you talking about the left headphone b button you can press?
из
It worked! Thank you so much ! :) back to listening hella music with great sound quality lol
из
it didnt work for me my power button light wont even turn on not even the other ligts
из
Показать ещё 108 комментариев
If your Studio or Studio Wireless headphones aren’t charging properly or you’re having difficulties with sound, try resetting your headphones.
RESET
Press and hold the power button for 10 seconds
Release the button
The Fuel Gauge LEDs will all blink white, followed by one blinking red
When the lights stop flashing, reset is complete
Your Studios will automatically power on after a successful reset
This feature helped me.
Hope it will help you too.
Best regards
Счет 20
26 Комментариев:
It's my 3rd day with new Beats Studio Wireless 2.0, battery was low so I plugged to charge, no gauge lights! Tried to reset by holding power down for 10+secs -still no light! :-( Now I'm here looking for help...
из
Thankyou so much. Couldnt figure why they weren't charging
из
Thank you so much this fixed my problem!!
из
Worked great!!!!! Thank you so much you just saved me some serious money :)
из
I am so thankful for your advice! Worked like a charm! I've had these 300$ headphones less than a year - I was truly upset, thought they were done, but after I tried the reset (which I didn't even know was possible) they work perfect again! Thank you so much!
из
Показать ещё 21 комментариев
What's going on?
I just had this happen to me. Came home from work and just wanted to listen to music but my Beats wouldnt turn on! I quickly searched and found this forum. Nothing helped my situationand on the Web. I did try this next thing and it worked for me!
The Beats lights would not turn on for nothing. I couldn't even get a red light! So I plugged them up after trying every reset possible (still no lights on). I then ran to Walmart to buy some back up headphones and to get an oil change on my car (was gone about two hours). When I came back, I held my power button down for about 10 seconds and it finally reset! Now it's working again! This worked for me and I hope it works for you!
(Also FYI only use a Beats charger to prevent over charging or damage to the battery)
TK
Счет 7
11 Комментариев:
No USB chargers contain overcharging circuitry... That is located in the headphones themselves. Feel free to use any 5v USB charger of any amperage.
On another note, glad to hear the hard reset was all that was needed :)
из
Thanks for that Info Mark. I only mentioned that because ever other occasion I use my fast charger that charges my phone to charge my Beats. I've noticed that they act funny almost always afterwards. Either they won't turn on or the light would blink red. But thanks again for that info.
из
TK, so the solution is to run to Walmart and get the oil changed ? Only then the headphones will perform a reset ?
из
Yo, did you ever figure out how to turn on and charge your beats? I'm having the same problem too!
из
Is it overcharging when they get hot while charging
из
Показать ещё 6 комментариев
I had that same issue and my problem was that the base of the charging cord wasn't all the way in so it wasn't charging all I had to do was push it in and my problem was solved
Счет 2
3 Комментариев:
When I plug in my beats all I get is white lights, no red. And after a time, when I'm sure it has charged, it still doesn't turn on!
из
I have been trying to turn my Beats 3 on for days, tried charging them etc and no white lights. Read this forum and it looks like I had not been pushing the cord in all the way, although it felt like it. So I really pushed in as suggested and now I have white lights. hopefully will charge and play wirelessly too. these are too pricey to have to deal with this issue. Thanks for all the suggestions on this forum.
из
My beats had all white lights with no red. I held down the little button that shows how many lights charge you have and the red button on the cord for 2 minutes while it was plugged. It worked for me the first time I did it. Hope it works for you.
из
If the hard reset technique doesn't work, you may be out of luck. I talked extensively with Apple Support about it as well, and they have no further documentation or troubleshooting techniques. Mine would be charged (tested - the battery had a full voltage) and would turn off after only a few seconds of listening at any volume level. The amount of time would vary based on how long it had been after a hard reset.
The "repair cost" of Apple makes sense because they probably don't even attempt repair. The circuit board inside the headphones all but requires damage to be disassembled, and Apple would not return a damaged product.
If you're curious, take a look at the teardown guide that I will be making in the next few days.
Счет 2
6 Комментариев:
Hi, are you close to posting the teardown guide?
из
By the looks of it, hopefully this weekend. I've done about a third of it so far.
из
Hi, the hard reset technique didn't work for me either , so are gonna posting the teardown guide anytime soon?
из
It's fairly late Sunday, so I can only say probably sometime within the week. You'll have to sit tight until then.
из
Показать ещё 1 комментарий
I had to reboot the beats approx 7X. Disconnect and repair. The beats/connect icon is not on my iPad screen but........the headphones are workin.
Счет 2
2 Комментариев:
what do you mean by disconnect and repair?
из
repeat probably
из
I have the wireless beats that just have the white light on and nothing happens. I've tried holding the power down, holding the power and the mute down as well as holding the power and the volume down. Nothing works! The light won't turn off an nothing happens! Please help!
Счет 2
1 Комментарий:
Same problem today i have today. I try to updated and something went wrong.
Now on left side light is on and I'm not able to turn it off either restart. :(
из
Hey guys I'm so depressed right now, I have beats studio wireless, the other day I over charged it and it shows red flash and stuff, so I tried to reset it and it still doesn't work, even the one holding the power button and the mute button for 2 minutes, and than I confused so I tried to hold the power button and the volume down button for like a minute or two, and suddenly it's dead, and I tried to do it again to turn it on but it's dead until now, please it's been 4 months it doesn't works. please give me solution i really need it, any advice I would appreciate it
Счет 1
1 Комментарий:
im having the same problem i think i might have over charge mine first it was a red light then the blue tooth started not working then i tried the cable that worked for a couple days then it started not working completely they dont even charge no more but when i put the audio cable and the charger cable and connect it to my phone it will work but not the blue tooth i need help let me know if you have found something
из
Hey guys I need help with my beats solo 3 wireless, in only have 1 light on the battery and I tried charging it and it won't charge, I also tried resetting for 10 secs and 10 mins and it doesn't work. Help.
Счет 1
Sounds like a class action lawsuit suit. I am experiencing the same problem. The unit will not charge, reset, or turn on. It is very sad since they are not cheap. Everyone should post to social media. I bet there would be a response from Apple then.
Счет 1
2 Комментариев:
Your RIGHT!!!!
из
I’m with you boy...shameless.
из
I also have Beats Solo 2, mine will not power on, they will charge and they will work when wired, but will not power on wirelessly. All resets don't work. HELP PLEASE
Счет 1
4 Комментариев:
I have the same problem, i have been trying to look for a solution'
из
Did you find any solutions
из
Nope. Nothing
из
Ran into the same problem today. Had tried all reset methods, but apparently none seems to be the real solution. Issue should have been the battery connectivity on the R(right) earphone piece, which is the charging side.
What I did was pull on the earpiece pads trying get a touch of the wires, but before I could, the earphone was back on with the bluetooth light on. Unfortunately, when I put the headphones on/off, or touch the R earpiece, by any chance the wires can be loosened again. Back and forth.
Consider all said, poor wire connections requires professional electrical background to really teardown the earpiece and tighten/fix the connection issue. My approach only temporarily solves the problem and allows me to use the headphone with caution. Which also might not be the same case for others.
Anyway, best of luck to all running into the same circumstances.
из
Your Studios do not turn on or seem to charge because the wires on your circuit board in your right ear have loosened or broke, due to improper jack or charger insertion. Fold your left ear, unclip your right ear cushion, then unscrew the 3 screws which are on the plastic part of the headphone not the alluminium part. You will see several dry joints on a small circuit board. 3 or 2 wires should be broken, one to send power to your right ear which should be gold and red. or either a black or red wire for your battery. bottom line, solder them back
Счет 0
1 Комментарий:
Your comment is misleading. This is one of many issues that can cause charging malfunctions. In most people's cases, this is definitely not the issue.
из
I tried both the reset methods to no avail. In the end I inserted the audio cable and then quickly removed it and this did the trick. I was listening via audio cable earlier in the day and I guess it still thought it was plugged in...?
Счет 0
3 Комментариев:
you are my hero that worked
из
You are awesome..it worked for me as well..
But it surely is a bug/defect in the model
из
Hi Paul. What does that mean? You inserted the audio cable into the beats and then quickly removed them? Were they attached to your computer?
из
worked for me! held 2 min and worked. Had same problem
Счет 0
So yeah I have tried this method like 10 times and when I hold the power button and mute button for 2 min, the light start flash all white and then one red for like 3 times, but then it just shuts down. What should I do?
Счет 0
1 Комментарий:
Could someone help me my Bluetooth will not work on my studio wireless headset I have reset it and everything . I see the whites and red. But I just can't get them to work
из
I have the same problem but the lights on my headphones just stay on when i hold they power button for 3-4 seconds then after that after 3 seconds they turn off there charging right now the red light is suppose to show but it wont it did last night but now there not charging what do i do?
Счет 0
1 Комментарий:
I have tried all of the methods and the light on my headphones won't turn on and when I connect the wire to my phone it doesn't even show a head phone is connected
из
Beats solo 3> I need help!
Im having this issue with my beats solo 3. They have trouble turning on and when they do they either turn off again or connect to my phone for only 5 seconds. I've tried charging them, and ive tried all the reset techniques. I even called the apple care line and all they said is to try the reset teniques again or go to the website that updates beats to see if they need an update (whitch they don't).
Is there a solution to this?
If not do you think it chip or the battery?
Счет 0
I'm having the same problem. I get the two red bleeps and then a couple of white lines and then it just beeps red again and dies. I just don't feel like they're dead, just not alive. Any other suggestions would be helpful. I've tried all the reset methods so far. Any new ideas?
Счет 0
These headphones are clearly don't work properly and have not been fully tested. For the price you pay, they're clearly not worth it. This is the second pair I have taken back to the store for a refund.
Счет 0
After a year, when my TM003 misplaced in the house, I found yesterday. When I put it on charging, indicator light turn red for few seconds then gone. After that no light. I tried every solution provided here but nothing worked. Please help.
Счет 0
when i plug my beats in the white light come on but after like 10 sec it turn right back of need help?
Счет 0
Mine would appear like they weren't charging, and when I tried to get them on I got the red flashing light, but when I went on the beats updater it said they were at 99% battery... I reset mine like a thousand times and nothing happened, but now they are working if I reset them, plug them in to charge, and then press the power on. Can't unplug them or turn them off without causing the cycle to start over again but it seems to be working for now....my warranty with apple is up and I'm not paying to repair or replace them so hopefully this resolves on its own...
Счет 0
I’m experiencing the same issue! It doesn’t seem to be worth all the trouble or money. They’re not working, not by the Apple methods or any other method of remedy. I’m close to giving up and tossing them.
Счет 0
Everyone, post to social media. I bet there would be a response from Apple then.
Счет 0
Don't buy beats.I have the same problem and nothing works.Take your beats apart and sell it for parts.Theres a lot of better headphone brands out there and a lot cheaper w/ better quality. It shouldn't be considered an Apple but a Lemon.
Счет 0
1 Комментарий:
I agree. Too many people having the same issue. I had my Beats just over a year but had barely used them. Additionally, I babied them - always putting headset and accessories back in the case just like when I first opened the box. Then one day, they stopped charging and no suggested methods worked. Called Apple Care. Walked through same reset method (I’d already tried numerous times) once with tech who then suggested I send them in for a refurbished set that cost only $100 less than original price.
из
Wow so I’m not the only one with issues apparently. Only have used my beats3 three dang times and now they won’t connect. Power light is stuck on and won’t turn off or do the reset. Nothing. I guess I’ll let them run out of charge and see if that works. They are seriously brand new!
Счет 0
Beta Solo 3 wireless.
One white led light stays on (ocassionally), won't charge, won't power on or off, will not reset (volume down and power button or mute and power button) and these are 15 months old, never abused, used authentic chargers and SUDDENLY STOPS working!!!! Of course outside of warantee!!! So upset that $300.00 headphones are an EPIC fail!
Счет 0
I have this problem after running for an hour. I can’t reset or charge my Powerbeats 3. I hang them up to dry for an hour so after which they seem to work fine. I suspect sweating is the cause of the problem.
Счет 0
1 Комментарий:
I have a charging issue too when I plug it in I get a flashing orange light then a flashing red light and then successive white lights and the sequence repeats its self over and over. When I plug the wireless earphones directly into the music source with a cable with the power connected or not it works fine . Do the batteries need to be replaced?
Any assistance will be greatly appreciated. Any suggestions for a comparable replacement that will last? - MIC
из
Beats Studios 2’s like the melt their USB’s while charging.If no lights come on while charging,check the USB to make sure it hasn’t separated from the circuit board.
Счет 0
It didn’t work, I’ve tried it 5 times, still won’t work, there’s 10 minutes of my time I’ll never get back :(
Счет 0
1 Комментарий:
Hey Lexi - mine took more than 2 minutes...they’re not plugged in or connected to anything, right? Not trying to waste more of your time, but in my case, patience eventually paid off...good luck!
из
Hi! I have the same problem! 2021!!! Someone knows how to fix it? I tried everything.
Счет 0
Hang in there and try again - longer than you think. I held it for well over 2 minutes and suddenly lights! Good luck!
Счет 0
I have no lights what so ever, I’ve tried the rest with the beats button and the power button for 2+ minutes. I honestly don’t know what other route to take. Any suggestions?
Счет 0
I recall someone saying to plug it in to a computer and leave for a while…not just plugged in to a wall charger. I was surprised that my “dead” phones awoke after holding the power for well over 2 minutes…good luck!
Счет 0
1 Комментарий:
Thanks man I’ll try it tomorrow.
из
Beats headphones are overated… I work in a studio and prefer pionears, jbl, or audio technical over beats…
Счет 0
Добавьте свой ответ
mitchellhost буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 22
За последние 30 дней: 93
За всё время: 596,590
