Unit won't power up
it doesn't power up (batteries or ac adapter) after being plugged into the wrong adapter. Is there an internal fuse link that can be replaced or???
Это хороший вопрос?
Это хороший вопрос?
Wow, not sure who woke this old question up, but here is my answer as well:-) there are actual three fuse on the PCB. The have the reference designator FU601,602, 603. FU 601 and FU602 are the power fuses.
FU601 part number VD7-3642-501 FUSE, Description KOA TF16AT2.50T
FU602 VD7-5071-000 FUSE, Description MATSU. DENKI UNHS206
Attached image show the location, check those for continuity. Hope this helps someone, good luck.
Был ли этот ответ полезен?
With mine I find dirty battery contact to be a problem.
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 20
За все время: 3,364
