The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
Power button pin out?
Hi,
In trying to replace the power button I delaminated one of the solder pads. It's not the ground side, it's the side that just goes to a buried via. Does anyone know where this connects - I'd like to bodge-wire something for now so I can at least get my data off the phone.
There's an image of the problem here : https://www.dropbox.com/s/dxhnafoavvm8k8...
Any ideas?
David
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
David Mills, check to see if this will help. Looks like it goes to R11010
Был ли этот ответ полезен?
Счет 4
3 Комментариев:
Thanks - just what I needed.
из
Thank you a lot! That was exactly the information I was looking for.
I had the same problem and now fixed it with a little wire bridge soldered between the resistor and the pin of the switch. I don't know how long it will last, but for it works :)
из
Thanks a million! You saved my N5!
из
Добавьте свой ответ
David Mills буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 2,226
