Двухъядерный процессор 1,6 или 1,8 ГГц, 2 ГБ или 4 ГБ SDRAM, SSD 64 ГБ или 128 ГБ
Keyboard row doesn't work
Whats up guys, I JUST finished changing my battery on my macbook, and now my a s d f g h j k l keys don't work, all other keys work fine. I was wondering if I might have loosened the keyboard cable or something. I'm going to take it apart again and see if anything is loose. Which cable is the one for the keyboard? Thanks.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
I'm sorry that you're having trouble with your keyboard. Unfortunately, Apple (we all know the designers at Apple can do this if they are feeling dubious) has decided to embed the keyboard in the upper case in your model, and the keyboard cable and assembly is in the upper case. Depending on how many repairs you have done before, this could take anywhere an hour for experienced professionals to three hours for beginners. If you want to proceed, you can use this guide (Замена верхней части корпуса MacBook Air 11" середины 2011 г.) to try again. You also may want to reseat the battery connector before trying. Hope this helps.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Good news, I removed the battery and wiggled the ribbon connectors and reassembled everything and it worked. The keys are working now haha I guess I got lucky. Thanks for your help anyways
из Поделиться
Добавьте свой ответ
Mark Chang буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 22
За все время: 449
