HP EliteOne 800 — это моноблочный настольный компьютер HP с диагональю экрана 23 дюйма.
Why won't my computer start?
My HP EliteOne 800 (unsure if it is a G1 or G2) will not turn on, no lights will turn on, or the screen is not showing any sort of responsive interface. It is making noises like it is running, but nothing is happening or it will not start at all and is completely unresponsive to all buttons.
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
Выбранное решение
Check the connection of the power cable both in the back of the PC and at the outlet. If the connections are solid then you should read this article from the troubleshooting page for more help: HP EliteOne 800 Troubleshooting
Был ли этот ответ полезен?
Счет 2
There is a Display Port output on the back. You might use a separate monitor to see if the display system has failed. Here's a tip. Examine the screen very closely with a flashlight held up to the screen. See if you can see the screen image on the dark screen. It may be that it boots up OK but the backlight has failed.
Счет 0
Добавьте свой ответ
Garett Jones буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 33
За все время: 1,955
