Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
Backlight is out
So I dropped my iphone the other day and it cracked the screen and I decided to fix it myself to see what it looked like inside and to save a few bucks. I got everything replaced (LCD and Digitizer) but the backlight wont turn on. I restored the phone, fiddled with the brightness and even took it apart again and tried to clean the parts that I messed with with alcohol. Anyone know what cable needs to be fiddled with to fix it.
---Note---
I tried to see what it would look like with my old LCD and the backlight is also out there.
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
The LCD connects to the logic board directly, via a single cable - Cable #1. Most likely, the logic board was damaged by the drop as well, causing the issue you are experiencing.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
well i hope thats not the case but when i dropped it and truned it on, the LCD backlight was still there so I dont think its damaged. how should I clean the connectors, people say toothbrushes but thats not helpful enough -_-
из
After installing ifixit's Front Panel Kit (glass and digitizer only), my backlight initially wasn't working.
The second time I removed and reinstalled the screen, I noticed a piece of dirt in the female (case back) part of the #1 connector, preventing it from seating fully.
Once the debris was removed and the screen reattached, the backlight was immediately functional.
Счет 1
Добавьте свой ответ
Tommy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 3,987
