Why does the lens won't operate
Why does the lens of my s860 digicam won't operate as normal?
Это хороший вопрос?
Это хороший вопрос?
i formally had a problem of lens not extending to the normal length on start up. the camera would make two beep sounds and shut down again. I then used my fingers to retract the lens at start up and the camera worked well . afterwards i decided to lubricate the mechanical portion of the lens and since then the camera lens has worked fine. I therefore recommend that once in a while the camera lens should be lubricated with fine thin oil, the type used with sewing machines.
Cheers!!
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 3,254
