Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Upgraded to El Capitain stuck on past splash page
I just upgraded an iMac to El Capitain and it stuck on the splach page. It would boot but just get stuck at the splash screen, loading bar would go all the way but then just get stuck,tried booting to safemode , ran disk util and to get to the terminal and played around in there nothing. Anyway decided to reinstall and its no joy stuck in the same spot. so I shut it down and decide to take a break from it . come back after 2 hours and figure id give it another try start the computer and it boots fine. Can anyone tell me whats going on . I dont want to return the machine till I know its going to work fine Can some of you Mac gurus give a hand here
Это хороший вопрос?
Счет 4
5 Комментариев
Jim, you know the drill - last four figures.....
из
the last four digits are DHUF
из
Look again on the bottom of your stand, those numbers do not work.
из
sorry need my glasses its a j not a u DHJF
из
Apple iMac "Core i5" 2.5 21.5-Inch (Mid-2011) Specs
Identifiers: Mid-2011 - MC309LL/A - iMac12,1 - A1311 - 2428
из
Добавить комментарий
1 ответ
Выбранное решение
Did you change the hard drive or anything else? Seagate 1 TB hard drive?
Almost as useful as a T8: https://www.micromat.com/products/techto...
Был ли этот ответ полезен?
Счет 3
7 Комментариев:
When the original update was don it was on a NIS it was then unmounted and move to do further testing it booted without the NIS so remounted it and it seems to be running fine now so I think it was the NIS . Im gonna check the logs now that its booted and see if thats the reason
из
What's a NIS?
из
Thanks for the help
из
NIS is network information service a client–server directory service protocol for distributing system configuration data
из
How's that working for you? Never used one, sounds like PC or UNIX to me.
из
Показать ещё 2 комментариев
Добавьте свой ответ
Jimfixer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 590
