lost windows windows corruption
how can i restore windows
Это хороший вопрос?
Get the appropriate windows disk for you OS then set your boot menu to boot from the optical drive . Once there select repair firs to see if your problem can be fixed that way if not then you will need to go to advanced and format the drive then reinstall windows. Make sure you have a valid oem key before starting . Hope this helps
Был ли этот ответ полезен?
Thank you I will have to get Windows disc and try this
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 83
2 Комментариев
What version of Windows is it? How far does it get into boot? Do you know the cause of corruption?
из gatewaynomad
Windows 10 I can't get pass utility screen
из betty alston
