Repair guides and support for vehicles manufactured by the Oldsmobile division of General Motors (GM).
41вопросов Показать все
replaced broken blower motor resistor block works worse now
2001 Oldsmobile Alero - my blower fan was only working on the highest 2 settings I replaced the resistor block and now it's only working on the highest setting does anyone know why this might have happened or what could b wrong?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
When the resistor goes its usually on the high settings if more than one works its usually the switch on the control that needs replacing . If it was the resistor and it went as soon as you installed it you need to replace the motor. Hope this helps
Был ли этот ответ полезен?
Оценка 2
pizon if the replacement of the resistor made it worse, double check your work and, if everything checks out, replace it once more.
Оценка 0
Добавьте свой ответ
pizon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 187
