Where can I find a charger port
Table won't charge will come on say connect to charger
Это хороший вопрос?
Это хороший вопрос?
Hi,
The Visual Land Prestige 10 can be charged 2 ways.
With the power adapter.
Connect the power adapter to the USB port in the Prestige 10 and to a power outlet.
With a USB cable.
Connect a USB cable to the USB port in the Prestige 10 and to a computer that is powered on. (Note: charging via a computer is slower than via a power adapter.
If it is not charging when using the power adapter, try using a USB cable connected to a PC. If this works then your power adapter is faulty.
If it is not charging when connected to a PC, try using a known working different USB cable. If you know that the USB cable is OK and it still doesn't charge, you either have a faulty charging circuit in the tablet or a faulty battery.
Был ли этот ответ полезен?
Hi @cdm1018 ,
Is the USB port damaged at all or is the tablet just not charging?
If it is just not charging, check the USB port enclosure using a strong light and a magnifying glass to ensure that there is no lint etc, trapped in there preventing a good connection and that all the pins are there and that they are straight and parallel with each other..
If the enclosure has debris lodged in there then try using a vacuum cleaner to suck it out. if it won’t dislodge do not use a metal pin or probe to try and clear it as you may damage the pins or cause electrical problems in the tablet. Try gently using a sharpened wooden toothpick instead.
If the port is damaged then the port will have to be replaced. If it is OK and the tablet is not charging, it may be that the port is loose from the systemboard.
In either event the tablet will need to be opened.
Here’s a link to the ifixit Visual Land Prestige 10 Motherboard Replacement guide. It is useful as it shows how to open the tablet to remove the motherboard. As the USB port is a SMD (Surface Mounted Device) type connector mounted on the motherboard, you will need SMD soldering skills and tools to effect the removal and replacement of the USB connector. This is not easy for a novice repairer.
As there are a lot of micro USB type connectors (different mounting configurations) you’ll also need the correct connector that suits your motherboard.
Here’s a link to just one supplier. There may be others online that may suit you better. (I think it’s the correct one but you may wish to compare it with the one in your tablet).
If you find this all too daunting, I suggest that you contact a reputable, professional, electronics or mobile phone repair service and ask for a quote to repair the port.
Hi @Patricia Moore,
Use a strong light and a magnifying glass to visually inspect the tablet’s micro USB charge port for any physical damage to the pins i.e. bent or missing.
If they appear to be OK, check the charger’s micro USB plug as well.
If the tablet’s charge port is damaged then see the answer directly above this one.
If the charger’s plug is damaged then see the Chosen Solution above about how to charge from a computer etc.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 1,494
2 Комментариев
So how do i replace the charging port?
из Colton
my charger want go in the port for to charge what I need to do
из Patricia Moore
