White vertical lines and unresponsive touchscreen
Hi, I wanted to replace my rear casing, however after looking at the battery, i noticed that my adhesive strips are to short, so i couldn't pull on them to get the battery out, instead of heating up the adhesive I gave up and decided to reassemble the iphone. I plugged in the battery and reattached the screen flex cables. When I booted it up, a lot of vertical white lines appeared and the touch screen became unresponsive.
PS (it's currently on 39% charge, I haven't tried to replug the battery and I haven't tried to clean the connectors)
Это хороший вопрос?
4 Комментариев
I was throwing books at my cousin while she had my iphone 5s and then the screen had these lines on them and then the touch screen was unresposive but everything works perfectly fine (buttons only work)
из Monique Enriquez
Is it the battery cables? Not the screen cables?
из Tony sun
Tried disconnect all the cables but it still doesn't work
из Tony sun
What worked for:
Disconnected the battery, disconnected all the screen connectors.
waited 10 seconds, air cleaned the connectors
reconnect the screen cables
reconnect the battery
connect the power cable and wait until it turns on by itself.
из Luis Carlos
