Выпущенная в Северной Америке в ноябре 2006 года, Wii стала первой домашней консолью Nintendo с прямой поддержкой подключения к Интернету, обеспечивающей как онлайн-игры, так и цифровую дистрибуцию игр и медиаприложений через канал Wii Shop Channel.
How do you fix a button that won't press?
The Wii took a tumble a while back, and since then, the eject button doesn't click anymore. Unless its positioned just right, it'll forever try to eject. How do you fix/replace an eject button?
Это хороший вопрос?
Счет 8
Добавить комментарий
6 Ответов
Наиболее полезный ответ
If I'm hearing you right, the console is constantly trying to eject the disc while the button is not being pressed. A solution you may want to consider is removing the button entirely (I'm pretty sure you can still eject the disc from the Wii menu). Try removing the faceplate to get to the button and remove it, to see if that fixes the problem or at the very least to clean out any broken plastic components that may still be in there. Wii Faceplate
Here's the part: Nintendo Wii Faceplate
EDIT: Whoops! Turns out you can't eject the disc from the Wii Menu. I tried through a whole episode of Seinfeld.
Replace the faceplate and its buttons. Изображение
Товар
$19.99
Был ли этот ответ полезен?
Счет 5
iFixit now has the part you need to repair your Wii (instructions linked to in BWest's answer)
Товар
$19.99
Счет 3
the eject button can be replaced but its very small. I use a digital microscope to clearly see the solder points.
Счет 1
clean the buttons some times got dust around
Счет 0
Yes and i need you to fix it
Счет 0
I took apart the Wii and found the disc holder and pushed the egect button a couple times then put it back together and the your set
Счет 0
Добавьте свой ответ
Kevin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 28
За всё время: 20,174
