Coolpix P530 — это цифровая камера с разрешением 16,1 Мп и впечатляющим 42-кратным оптическим зумом. Эта модель была выпущена компанией Nikon в феврале 2014 года. Она также известна под модельным номером производителя Nikon 26464.
Why is the flash not working?
As I was taking pictures in low light conditions, my flash would not turn on. I was still able to capture images, but they were terribly dim.
Это хороший вопрос?
Счет 1
1 Комментарий
My flash only works when i switch it off and then on again but only for the one time. If i have to take another picture using the flash again means I have to turn off and on again
из
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
Have you ensured that the 'mode' that you are using allows the flash to operate?
Here is a link to the user guide which shows in which modes the flash is not available.
http://www.manualslib.com/manual/788820/...
Here is a link which shows the available flash 'modes' and also how to tell if your flash is ready.
Был ли этот ответ полезен?
Счет 2
If the flash is not working on your camera, the first thing to do is to make sure the flash is enabled. This can be easily done by finding the correct setting in the camera’s menu. If you are having trouble finding this menu, or are still having trouble with the flash be sure to check out the Nikon Coolpix P530 Troubleshooting page on iFixit.com. It will have more helpful information to help you get your flash working properly.
Счет 2
Добавьте свой ответ
Sydney Cardinali буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 21
За всё время: 5,597
