The InFocus LP540 is a digital projector, which provides video and computer inputs. It has a XGA 1024x768 resolution. The repair requires screwdrivers and other useful tools.
projector picture shows only half
projection from CPU only shows half the picture on screen
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Выбранное решение
Sounds like a bad screen inside, these projectors run of a tiny little pc screen with a massive light behind them and a lens in-front, sounds like the little screen is buggered and im afraid to get a replacement would cost more than a new projector.
Although it might be worth making sure that something hasn't come loose and is just sitting between the lens and the light, have a look in the lens WITH THE UNIT OFF so u don't blind yourself and see if it looks like something is blocking half of it.
Also the half that is not showing is it white or black?
Был ли этот ответ полезен?
Счет 1
Select 1024x768 resolution from your computer
Счет 0
Go on your computer/laptop settings and type in projector, look through some of the settings and click (second screen only)
Счет 0
Добавьте свой ответ
rporter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 3,685
