Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
Only works with speaker activated.
When making or recieving a call I need to activede the speaker on my Iphone othervice the I can't hear and the reciever can't hear me.
What do I need to change?
Это хороший вопрос?
Счет 1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
The most common source of this issue is debris in the headphone jack causing the sensor inside to continually detect headphones. This in turn forces the phone to turn off the receiver earpiece and mic. The most common source of this debris is pocket lint, BTW.
You can also test this by playing a track in iPod mode - if it doesn't play thru the speaker, and the volume control indicates headphone adjustment with no headphones connected, then the sensor is being triggered.
Try blasting compressed air into the headphone jack in a series of short blasts. The debris can also sometimes be cleared by repeatedly inserting and removing headphones from the jack.
Был ли этот ответ полезен?
Счет 1
Have you taken your iPhone apart? If so, it could be that ribbon #3 is out of place- that one corresponds to the earspeaker.
Счет 0
How far is the #3 cable supposed to go into the phone? it looks as if there is a white line with an arrow pointing to it. Should it go in that far, or only until the "light" colored brass in all the way in?
Счет 0
i dont think it goes all the way to the line, well i couldnt get it that far and it wasworking fine.
Счет 0
Добавьте свой ответ
kim буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 6,606
