Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
Вопрос закрыт
Realigning a new laser in SCPH-30001R
Hi Everyone,
I recently replaced the laser in a SCPH-30001R, and realigned the laser so that it could read discs. After I realigned it though, it would only play PS1 discs and blue PS2 discs. When I would try to test a silver PS2 disc or my laser cleaning disc, the drive would making buzzing noises. (Versus no buzzing at all with the PS1 and blue PS2.) Should I keep trying to align it, or I'm I missing something? The laser model is a KHS-400C, the same model that I found in the system before replacement. When I first installed the laser without any adjustment to the laser angle, the system would not load any discs.
On a side note, I have another SCPH-30001R, that takes longer than normal to load a disc. Is there anything I can do to improve the load time?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
@supportninja you can try to further adjust the laser and see if that will work. Of course it will also depend on how your are adjusting it. Take a look on here as well as the answer Disc is not spinning with a new laser PlayStation 2 for that. There were issues with the laser and the alignment on the PS2.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
I think I know what the problem is now - When I installed it, I am fairly certainly I screwed in the angle screw on the rod all the way. I'll give adjusting it a try and post the results.
из
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,727
