The Alienware M14x R2 is a 14-inch gaming laptop.
12вопросов Показать все
laptop shell cracked I need a replacement for alienware M14r2
my alienware laptop shell cracked on the right bottom side so the top half and bottom half are cracked so it always opens near the CD drive i am trying to find a way to by a whole new shell top and bottom but have no idea on how to do so
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Your best bet is to contact Alienware for the parts you need you may be able to find them on ebay or amazon as well but in most cases when the case is broke I use an epoxy called JB weld open the case and where its cracked on the inside apply the 2 part epoxy and it will hold like it was new. Its really strong stuff. Hope this helps
http://www.jbweld.co.nz/wordpress/wp-con...
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Josh Warszawski будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 6
За всё время: 680
