Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
recover data from phone dropped in water
I dropped my iPhone into quarry water. The phone got hot after removing it from the water.
I'm sure that the battery is destroyed, but is there a way to recover stored data from the phone?
Update (06/26/2016)
First, this is my son's iPhone which he dropped into quarry water while foolishly quarry diving. The iPhone is eligible for an upgrade after buying out the remainder of the purchase plan[$167]. But he has data on the memory chip that he needs.
Hypothetically, is there a way to access the memory chip after the phone is disassembled? What would be needed to accomplish this task? Think, forensic options.
He did not backup his phone.
And, [re, my iPhone] senior Apple technicians have been unable to get my iOS devices to backup to my iTunes. The development team told the senior rep that there is a bug that they have not fixed that prevents high capacity iOS devices [128GB] from creating iTunes backups, and there doesn't seem to be any third part software available to accomplish a backup. I have been trying to get this addressed since last October when iOS 9 came out and my backup capability was trashed either by iOS 9 or the Yosemite/ElCapitan OS upgrades.
So, problems of having no backups are not necessarily the users fault.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
To recover data from the iphone you need to fix it and get it running. If the phone doesn't work there's not really an easy way of removing the data
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
iCloud backup on computer?
из
@binsujiro I totally agree with @jimfixer . If it does not power up and does not get recognized you cannot get your files.
I suggest you treat this just like any other water damaged iPhone. The very first thing you want to do is to clean it. Disassemble your phone using this guide. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Just soaking it will not help. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone, replace your batteryand reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try and hope it powers up long enough to get your files off it.
The memory IC's are encrypted and paired with multiple other IC's on that particular board. Again, unless you get it to power up there is no way to access the files.
iPhone Изображение
Инструкция
Repairing iPhone Liquid Damage
Сложность:
Сложно
1 - 2 hours
iPhone 6 Logic Board Изображение
Инструкция
iPhone 6 Logic Board Replacement
Сложность:
Модерировать
30 minutes - 2 hours
Оценка 2
Добавьте свой ответ
Vincent Ferri будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 220
