Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
Battery seems to be damaged
A few days ago I dropped my phone from my pocket. It landed on the bottom left corner. And a few hours later the phone died but it said 55% near the battery icon before it shuts off. I plug my phone in the charger and a minute later the phone turns back on with 67% battery (at least it said so). I though everything would be fine but later that day the battery died again with roughly 60% charge. I tried to reboot the device by holding the power button and home button. The phone turned on and shut down after a few seconds. When I got home I put my phone in DFU mode and recover the phone because I though the jailbreak tweaks kills the battery. No hope. I run several Geekbench and here are the results it showed that it decades from 99% to 62% in half an hour. It also shows that when the battery reaches 83% it immediately dropped to 76%. I ended up wrapping my battery in newpaper and throw it in the freezer for 12 hours. No hope
P.S the phone dies when it reached 55% (half an hour usage) and it shuts off. When it turns back on it is at 67%
P.P.S Battery apps shows that my battery capacity is at 87%/89% (either of them). When I charged it overnight they shows that my battery is at 92%
P.P.P.S I didn't put adhesive at the battery. But it survived tons of drops. It is possible that a single drop can take out the battery?
Это хороший вопрос?
Оценка 0
1 Комментарий
change battery also charging hub
из
Добавить комментарий
2 Ответов
Выбранное решение
更换新的电池就可以了。网站iphone修复有教程。这个是电池老化的原因。
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
It's either a faulty battery or the battery gauge fuse / component chip has been chipped off / damaged. It's located above the battery connector for the iPhone 5s battery.
It's best that you try replacing the battery first as it's a lot cheaper and easier to do. If the same issues still occur you are probably looking at a board level repair which is not DIYable, you will need to take it to a repair shop that does board repairs. I unfortunately don't know what stores that do it.
Guide to replace the battery:
How to replace the battery in your iPhone 5s
You can buy the battery from the iFixit parts store here:
iPhone 5s Battery
iPhone 5s Battery Изображение
Продукт
iPhone 5s Battery
$29.99
Оценка 3
1 Комментарий:
good...............
из
Добавьте свой ответ
L HK будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 112
