The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
How to fix RB on Xbox one controller
The right bumper is either getting stuck or broke because it does not click down like the other bumper does how do I fix this ?
Это хороший вопрос?
Счет 8
Добавить комментарий
1 ответ
Take the controller apart and see what is causing the issue. Clean out any debris or liquid, sometimes people get liquid inside without knowing it. Spray from opening a can of soda or Monster type drinks can get inside these joints and cause them to be sticky.
Once the controller is apart, clean the button and all the plastic casing around it. After the make sure the button works mechanically and that it is able to be depressed. If not you may be able to see what the problem is.
Guide: Xbox One Controller Trigger Replacement
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Joseph z буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 15
За последние 30 дней: 35
За всё время: 57,973
